http://bbs.pigoo.com/thread-24007-1-1.html dna1002d pinout chrome translate
1) LATCH When the over-voltage under-voltage, this pin is high, this pin is low, the output is normal.
2) COM signal ground
3) PG normal operation this pin is high PG output.
4) TDON a capacitor connected to ground, resulting in PG delay.
5) REMOTE REMOTE ON / OFF terminal is low is ON, the high is high Pin1
6) TDOFF a capacitor connected to ground, play a role in delayed shutdown, resulting in PF
7) DUV capacitor connected to ground, so that the capacitor charging voltage is less than 2.5V reference voltage, not
Made under voltage detection, and when the charging voltage is greater than 2.5V reference voltage, under voltage detection restored.
8) BSENSE within the IC, the Pin is the same supply voltage phase comparator input
When the Pin voltage is below 2.5v, then Pin3 and Pin7 become low.
9) V5 +5 V over-voltage detection and under voltage, the UUP point of 4.0 ~ 4.24V, OVP point is 6.0 ~ 6.39V
10) V12 +12 V over-voltage detection and under voltage, the UUP point 9.4 ~ 9.99V, OVP point of 14.45 ~ 15.35V
11) V-12 test-12V over-voltage and under voltage, the reference voltage pin connection, loss of this function
12) V3.3 3.3V over-voltage detection and under voltage, then this pin Vcc, then the loss of this function, the UUP point is 1.09 ~ 1.16V, OVP point is 1.43 ~ 1.52V
13) V-5 test-5V over voltage and under voltage, the reference voltage pin connected, the loss of this function
14) RCRNT resistor connected to ground, resulting in the internal constant current
15) VREF 2.5V reference voltage output
16) Vcc IC power
Проблема с БП от Дельта (Delta) DPS-800GB
  • Вот результат моей 8-ми часовой работы над этим
  • У меня только DNA1001D... Приду с работы и сделаю
  • Если не сложно, то please. Или хотя-бы pinout
  • "Во всех нет дежурки." и "Где бы
  • Есть у меня один рабочий БП на такой
  • Попало и ко мне 3 штуки DPS-800GB от
  • http://bbs.pigoo.com/thread-24007-1-1.html dna1002d pinout chrome translate
  • Принесли два таких же БП. Внутри много пыли, пылесосом
  • а может они вылетают после продувки
  • со времён царя гороха пылесосом чищу... кисточкой
  • А может пылесосом вы сдвигаете электролит, нарушая контакт?
  • Но почему же тогда вылетают они после продувки
  • Спасибо всем за внимание. Проблема не в пылесосе а
  • Аналогичная ситуация. Не хотят эти БП дружить с пылесосами. На
  • Дружище lin999, уже заждались твоих фоток, выкладывай скорей
  • Пардон.весь в делах со всем вылетело из головы.завтра
  • очень нужна схема на данных БП, выручите кто
  • to lin999, А в какой именно понедельник выложите?
  • у меня один заработал.узнал только сегодня.в понедельник выложу
  • проглядел всё...всё на месте...хотя возможно в "дремучем
  • Это из области фантастики. Вероятно "лёгкая чистка"
  • Добрый день....имею на руках 2 таких БП.ситуация следующая...привезли
  • А схему то на DPS-800GB нашли? Если нашли, то,
  • Судя по насыщенности платы управления, низкой и
  • >Не втыкает по логике, маловато будет даже если
  • Не втыкает по логике, маловато
  • Это тоже самое, что в обычном БП
  • Залез в кишки. Монтаж очень плотный. Странно правда,
  • При чем тут +5V???? Ну нету там окромя
  • По любому, там должны быть выпрямительные элементы, вот
  • По порядку: обозначений на плате нет, кроме цифири
  • Всё хорошо, только у этого БП нет +5В
  • Имеется в виду использование в качестве блока
  • А придется. Резистор 1 ком подключить к
