2ivp
Да все тажа ботва насчет BP v.4.51 отпатчил - залил - не грузится - клавой правда моргнет разок - что ,несомненно, радует -)) Клаву вынимаешь - так ей уже и моргать нечем - а плата не грузится.
А лог пжалста тире скока угодно:
(c)2002-2003 apple_rom, www.ROM.by
C:\patch>bbb kd.bin /m
BIOS Patcher ver. 4.51.
Found 2Mbit BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support :for skip this step press "s" or any another key fo
-> fixed....
Mobile AMD Multipl-r adding :0000for skip this step press "s" or any another ke
y for continue...s
2. XP frequency :for skip this step press "s" or any another key fo
-> fixed.his step press "s" or any another key for continue...
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
for skip this step press "s" or any another key for continue...
14.Set "Y" as default on exit: not found.
Tweak options addinng:
Bus Disconnect Support : -> fixed.her key for continue...
FID_Enable adding : -> fixed.
Display Features adding : -> fixed.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 33.4%
Adding tweak.tmp 65.5%
Adding start.tmp 87.5%
C:\patch>
2ivp
-> fixed....
y for continue...s
C:\patch>
Альфу 10 что ли натравить на это дело ? -)))
