Gigabyte GA-7VRXP на VIA KT-333
DOS/4G Protected Mode Run-time Version 2.01a Copyright (c) Tenberry Software, Inc. 1996
!! Module Manipulation Successful !!
Found AMD K7-BIOS/platform!
Adding all AMD K7-steppings : -> fixed.
4. 32Gb-problem : not found. FID_Enable adding : -> fixed. Bus Disconnect Support : -> fixed. Adding AMDK7NOW! support : -> fixed.
!! Module Manipulation Successful !! DOS/4G Protected Mode Run-time Version 2.01a Copyright (c) Tenberry Software, Inc. 1996
if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by
Патчилось BP-6a5 с amibcp75. Прошилось родным Q-Flash. Глюков ПОКА не замечено.
