Аналогичная проблема (BIOS ROM file overflow) - MSI KT6 Delta (KT600)
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required!
Found 4Mbit AMI BIOS!
!! Module Manipulation Successful !!
Found AMD K7-BIOS/platform!
Adding all AMD K7-steppings -> fixed.
4. 32Gb-problem not found. FID_Enable adding -> fixed. Adding AMDK7NOW! support -> fixed.
Tweak options addinng Bus Disconnect Support -> fixed. Display Features adding -> fixed.
Error 9 - BIOS ROM file overflow. Bytes Free = 004F9( 1273), Module Size = 00B6D( 2925), 00674( 1652) Bytes needs
!! Module Manipulation Failure !!
if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by
