msi kt3v bios 1.A0
BIOS Patcher ver. 6.00.alpha4. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required!
Found 2Mbit AMI BIOS!
!! Module Manipulation Successful !!
Found AMD K7-BIOS/platform!
Adding all AMD K7-steppings : -> fixed.
4. 32Gb-problem : not found. FID_Enable adding : -> fixed. Bus Disconnect Support : -> fixed. Adding AMDK7NOW! support : -> fixed.
if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by
msi kt3v bios 1.A0
