На Online команды Flash ПЗУ должен как-то
На Online команды Flash ПЗУ должен как-то реагировать?
Online CR: Rev 0011.0000, Flash, Abort
Online ESC: Rev 0011.0000, Flash, Abort Looping Command or Batch File
Online ' ': Rev 0001.0000, Flash, Pause Output
Online '.': Rev 0011.0000, Flash, Display Active Status
Online '?': Rev 0011.0000, Flash, Display Diagnostic Buffer Information
Online '`': Rev 0012.0001, Flash, Display Read/Write Statistics
Online '$': Rev 0012.0002, Flash, Display Read/Write Statistics By Zone
Online '{': Rev 0011.0000, Flash, Toggle EIB-Specific R/W Tracing
Online ^D: Rev 0011.0000, Flash, Toggle R/W Tracing
Online ^N: Rev 0011.0000, Flash, Toggle R/W Tracing
Online ^W: Rev 0011.0000, Flash, Enable and Init RW Statistics
Online ^O: Rev 0001.0000, Flash, Advance Servo Tracing State
Online '!': Rev 0011.0000, Flash, Display Current Read Channel Settings
Online '<': Rev 0011.0000, Flash, Decrement Read/Write Scope Sync
Online '>': Rev 0011.0000, Flash, Increment Read/Write Scope Sync
Online '~': Rev 0014.0000, Flash, Display Native Interface Command State
Online ^A: Rev 0012.0000, Flash, Display Firmware Revision
Online ^B: Rev 0012.0000, Flash, Get Thermistor Temperature
Online ^C: Rev 0011.0000, Flash, Firmware Reset
Online ^E: Rev 0011.0000, Flash, Display Native Interface Configuration
Online ^F: Rev 0011.0001, Flash, Display Native Interface Read Cache Information
Online ^I: Rev 0011.0000, Flash, Display Controller Registers
Online ^K: Rev 0011.0000, Flash, Display DST Status
Online ^L: Rev 0023.0000, Flash, Display Sign On Message
Online ^P: Rev 0011.0000, Flash, Toggle Diag Idle Mode
Online ^Q: Rev 0011.0000, Flash, Resume Interface Task
Online ^R: Rev 0011.0000, Flash, Enable ASCII Online Serial Port Mode
Online ^S: Rev 0011.0000, Flash, Pause Interface Task
Online ^T: Rev 0011.0000, Flash, Enable ESLIP Serial Port Mode
Online ^U: Rev 0011.0000, Overlay, Display Congen
Online ^V: Rev 0011.0000, Overlay, Toggle Interface Command Echo
Online ^X: Rev 0012.0000, Flash, Display Native Interface and Read/Write Command History
Online ^Y: Rev 0011.0000, Flash, Display DST Status
Online ^Z: Rev 0011.0000, Flash, Enable ASCII Diagnostic Serial Port Mode
Online ^\: Rev 0011.0000, Flash, Toggle Debug Display Enable
All Levels CR: Rev 0011.0000, Flash, Abort
All Levels '/': Rev 0001.0000, Flash, Change Diagnostic Command Level, /[Level]
All Levels '+': Rev 0012.0000, Flash, Peek Memory Byte, +[AddrHi],[AddrLo],[NotUsed],[NumBytes]
All Levels '-': Rev 0012.0000, Flash, Peek Memory Word, -[AddrHi],[AddrLo],[NotUsed],[NumBytes]
All Levels '=': Rev 0011.0002, Flash, Poke Memory Byte, =[AddrHi],[AddrLo],[Data],[Opts]
All Levels '@': Rev 0001.0000, Overlay, Batch File Label, @[LabelNum]
All Levels '|': Rev 0001.0000, Overlay, Batch File Terminator, |
All Levels '*': Rev 0011.0000, Overlay, Special Batch File Function, *[FuncId],[FuncParm0],[FuncParm1]
All Levels 'A': Rev 0011.0000, Overlay, Set Test Space, A[OptsOrParmSelect],[ParmValue],[AddrType],[HdForCylLimit]
All Levels 'L': Rev 0001.0002, Overlay, Enable Looping, L[Opts],[CountOrStopOnErrCode]
ST1000DM003
