Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Есть такой транзистор- T3866 производитель- TOBA, но, к сожалению, никаких сведений на него найти не удалось.
В общем для экономии времени поступил просто - попробовал и то и то на низком напряжении.
2N60 - свистело-скворчало
13007 - отлично пошло. Работает.
Завтра пройдет тест, посмотрим.
КСТАТИ! Интересная дежурка! Не было времени разбираться, но вторичка транса включена очень оригинально!
Значит так. Один отвод как обычно через диод на питание ШИМ-а, 12 В. Второй отвод НАПРЯМУЮ на выход дежурки!!!! ИМЕННО ТАК! А третий - через здоровенный диод, включенный КАТОДОМ к выводу, НА ЗЕМЛЮ. ИМЕННО ТАК!
Я сразу не понял, откуда на выводах вторички транса постоянка взялась, когда осцилом смотрел. Потом не понял, почему на одном выводе толстого диода импульсы есть, а на втором полный ноль. Потом не понял почему второй вывод диода звонится на землю. Потом проследил дорожки.
Смелый Вы ezhik97, в дежурку 13007 ставить.
Обычно из биполярных там Fairchild KSC5027 (800V) живёт, что и рекомендую.
Достаточно часто применяемая в хороших БП схема.
Вот, а корпус с таким БП стоит всего-то 25 баксов
А про 13007 я где-то сдесь и читал, что меняют ключи дежурки на 13007.
В дежурке Эспады встречается и 13003. Года два полета у таких Эспад уже есть. Схему такую тоже иногда видел. Проверять проще полевик или биполярный, по сопротивлению силовой обмотки транса дежурки. В схемах с полевым сопротивление около 2 - 2,5 ом, с биполярным обычно выше, вплоть до 7 ом.
Кстати вопрос. Закупили кучку SPP03N60S5 (я для дежурки просил), у них Rds 1,5 ом, а не 4,4 или типа того. Кто нибудь ставил такие в дежурку?
atxbp.narod.ru/
Хм, а чем плохо более низкое сопротивление? По-моему всё должно работать ничуть не хуже.
Я ставил. Нормально работает.
Господа,
надо заменить в БП 250Вт горелые силовые D4242, есть донорские MJE 13005. Подойдут?
И что за зверь такой - K3067 (дежурка), не могу найти на alldatasheet
на счёт транзистора K3067: посмотрите, оно или нет
datasheet4u.com/share_search.php?sWord=2SK3067&x=30&y=11
На 250Wt подойдут. Но лучше с запасом - MJE13009(L).
