Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
SPW20N60- 29А 600В Rканала=0.19 Ом.
SPW02N60- 2А 600В Rканала=3 Ом.
Михаил.
ЗЫ
nmd.nm.ru/5VSB/SB%20-02N60P.jpg
Есть Бп, нашел сгоревшими транзюки NT407F C4304, стоят по высокому напряжению, немогу найти аналог, прошу помочь чем можете.
я подозреваю что D209L какя-то дешёвая сыромятина, мне попадались в новых FSP 300W и 350W ,разорванные на куски.
Не зря видать эти БП дешёвые . Вместо них ставил 2sc2625 ,так проще, или MJE13009.
А насчёт размышления какие мощные NPN лучше и вообще на все случаи жизни подходят - дак это всё пустое.
все они по параметрам примерно одинаковые 400В и выше,
8А и выше, 50Вт и выше, время около 1мкс .
остаётся главное - цена и доступность что временами означает одно и то же.
Так что 2sc2625 и (MJE)13009 Forever!!!
маркировка____Uис___Iс___Pmax__Rmax____Цена
2SK1358_______900___9___150___1,4______67 руб.
2SK1462_______900___8___150___1,6______78 руб.
2SK1464_______900___8___80____1,4_____104 руб.
2SK1794_______900___6___100___2,8______66 руб.
2SK2038_______800___5___125___2,2______49 руб.
2SK2039_______900___5___150___2,5______54 руб.
2SK2101_______800___6____50___2,1______49 руб.
2SK2651_______900___6____50___2,5______25 руб.
2SK2677_______900__10____65___1,4______80 руб.
2SK2771_______900___9___125___1,4______91 руб.
2SK2717_______900___5____45___2,5______** руб.
это силовики вместо STW10NK90Z и ему подобных,
из того, что можно купить в Красноярске.
Лично я до сих пор ставил 2677 или 1358, но это дорого.
Другие не пробовал, хочу проверить 2651 .
800-вольтовые не уверен стоит ли ставить, хотя 600-вольтовые попадались в
БП типа линкворда" border="0" src="http://forum.rom-by.com/images/smiles/icon_eek.gif" />, естественно трупы Добавлено спустя 13 минут 57 секунд:
до сих пор не понимаю зачем с таким запасом по току ставят транзюки.
ШИМ-ка 3843 всё равно работает в режими ограничения тока,
если он больше чем надо." border="0" src="http://forum.rom-by.com/images/smiles/icon_confused.gif" />
Добавлено спустя 8 минут 8 секунд:
там в цепи истока 2-х ватный резюк стои как датчик тока на 0,15 Ом кажется ,
у меня не было такого , поставил 0,24, так он у меня (БП) полную мощу не выдавал 400 Ватт , до 250 доходил а дальше если нагрузку увеличивал , выходные напруги плавно снижались." , пока нужный номинал не впаял.
2 egor-land
Спасибо за информацию.
600 вольтовые действительно в схему 3842 нельзя, порвет их в клочья. Народ пробовал. Во всех фирменных блоках как минимум 800. Запас по току потому что при высоких температурах этот запас сильно уменьшается. С резистором у меня было похожее, только он поплыл сам на увеличение. Тестером тогда помереть не получилось, флюка не было, вымерил с помощью ESR метра, он до сотых ома. Долго понять не мог почему не тянет, цепь регулировки через оптрон всю перерыл. В фирменных блоках видел резисторы, как толстая сплющенная металлическая проволока, с выдавленным номиналом. Они вечные. Купить такие не нашел. Да, еще вопрос, а в дежурку какие полевики дешевле и надежнее?
_________________
atxbp.narod.ru/
atxbp.narod.ru/
2 micbal
Какие ставить в дежурку не знаю, ибо не разбирался с этим.
А вот почему там стоят 600-вольтовые , 02N60P например в InWin-ах ,не очень понимаю" border="0" src="http://forum.rom-by.com/images/smiles/icon_confused.gif" />
Наверно по-этому дежурка в этих БП так часто выгорает
2 egor-land
В инвинах всегда где взорвался полевик прихватив транс, высохший конденсатор С34. В среднем от емкости остается 7, а и иногда и до 5 микрофарад. ESR всегда в бесконечность. В других блоках дежурка на полевике горит редко, скорее всего либо из за перенапряжения, либо перегрева.
_________________
atxbp.narod.ru/
atxbp.narod.ru/
Ребята, какие транзисторы Вы ставите вместо 5027.
Просто, ради любопытства.
Михаил.
NMD
Если нет 5027, ставлю с доноров 4106 и подобные слабые силовики. Если нету таких, то 13007 новые.
_________________
atxbp.narod.ru/
atxbp.narod.ru/
BUT11, BUT12
