при включении в окне терминала: V`tchdog Int installed!!!
RedBoot(tm) bootstrap and debug environment [ROMRAM]
Non-certified release, version v2_0 - built 15:51:55, Mar 20 2008
Platform: TCAT DICE/VB (ARM7TDMI)
Copyright (C) 2000, 2001, 2002, Red Hat, Inc.
RAM: 0x00000000-0x00800000, 0x00016528-0x007ed000 available
== Executing boot script in 20.000 seconds - enter ^C to abort
PedBoot> fis load dice
@edBoot> go
semID_FlashWriteActive: 0x00000021
dapInitializeInterface: nbPersistData = 0x000032a0 bytes
StandAloneInitialize: Clock rate is 2
StandAloneInitialize: Clock source Internal
@DC Read: 0
pargetUpdateOpticalOutput:
DAP Space: 00002374
( TC Command Line Interface System *
( Copyright 2003-2007 by TC Applied Technologies Ltd. *
* Running Dice JR/Mini 1394 Appl *
* Chip Detected : DICE JR (TCD2220) *
Board S/N: 00010058, SDK Ver.: 03.04.01, build 5782 *
( Application Ver.: 00.000 *
* - built on 11:18:25, Aug 13 2009 *
* MIDI is enabled. *
* Target: Focusrite Pro40 *
* Driver: DiceDriver *
* AVS special memory partitions *
Focusrite Software Version: 1.5r0, Build 1501
>bwitchThread - started
`DDR_MSG_DISABLE
setADCMutes: Muted
retADCMutes: Muted
retADCMutes: Muted
Rample Rate 48000Hz
Hocked (Stand: OFF, Con: OFF, Stream: OFF)
Focusrite Saffire Pro40 - не определяется по FireWire
