Сегодня наконец-то удалось раздобыть USB -> UART Подцепился к карте и вот что она мне отвечает:
Watchdog Int installed!!! RedBoot(tm) bootstrap and debug environment [ROMRAM] Non-certified release, version v2_0 - built 15:51:55, Mar 20 2008 Platform: TCAT DICE/VB (ARM7TDMI) Copyright (C) 2000, 2001, 2002, Red Hat, Inc. RAM: 0x00000000-0x00800000, 0x00016528-0x007ed000 available == Executing boot script in 20.000 seconds - enter ^C to abort RedBoot> fis load dice RedBoot> go semID_FlashWriteActive: 0x00000021 eapInitializeInterface: nbPersistData = 0x000032a0 bytes StandAloneInitialize: Clock rate is 1 StandAloneInitialize: Clock source Internal ADC Read: 126 targetUpdateOpticalOutput: ADAT (0x00002911) EAP Space: 00002374 ********************************************************** * TC Command Line Interface System * * Copyright 2003-2007 by TC Applied Technologies Ltd. * ********************************************************** * Running Dice JR/Mini 1394 Appl * * Chip Detected : DICE JR (TCD2220) * * Board S/N: 00030244, SDK Ver.: 03.04.01, build 5782 * * Application Ver.: 00.000 * * - built on 11:18:25, Aug 13 2009 * * MIDI is enabled. * ********************************************************** * Target: Focusrite Pro40 * * Driver: DiceDriver * * AVS special memory partitions * ********************************************************** * * * Focusrite Software Version: 1.5r0, Build 1501 ********************************************************** >switchThread - started eDDR_MSG_DISABLE setADCMutes: Muted Standalone Routing: LOW Mode Sample Rate 44100Hz Locked (Stand: ON, Con: OFF, Stream: OFF) setADCUnMuteTimer eDDR_MSG_DISABLE setADCMu�es: On eDDR_MSG_DISABLE �DDR_�SG_DISABLE �DD�_M����IS�BLE�
После никаких признаков жизни, firewire не поднимается - значит сдох TSB41AB2? Надо паять?
