Messed up text on POST screen
Hello everyone!
I have successfully used Bios Patcher, with the /m command on top of an already modded BIOS, to fix an UDMA problem on a VIA MVP3 chipset motherboard (PCChips M577)
And for this, I am VERY thankful to the creator(s) of this wonderful little program!!
The problem is that the text string that Bios Patcher adds to the POST screen (www.ROM.by, BIOS patch v.4.23) pushes down the text that is below, and makes it overlap over the CPU name : (
How can I apply Bios Patcher on my bios, without it adding extra text to the POST screen?
Or how can I change it, and remove some of the empty lines underneath it?
This is my patch report:
BIOS Patcher ver. 4.23.
Found 1Mbit BIOS!
1. New CPU Support :for skip this step press "s" or any another key for continue...s
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support :for skip this step press "s" or any another key for continue...s
4. 32Gb-problem : not found.
5. Some HDD detect-problem :for skip this step press "s" or any another key for continue... -> fixed.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : is not needed to be fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit:for skip this step press "s" or any another key for continue...s
Write Allocate addinng: not found.
UDMA for "big"-HDD on UDMA33_only_MB fix:for skip this step press "s" or any another key for continue... -> fixed.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 24.3%
Adding start.tmp 87.5%
(c)2002-2003 apple_rom, www.ROM.by
Also, can anyone please tell me, what is that "hidden" step, that needed confirmation, between 13. and 14. ???
I accepted it, as I didn't know what it was, and thought it might be essential.. But what is it??
Thank you in advance.
All the best to everyone here!
