извеняюсь за долгоет молчание полерял тему :oops:
в общем частично разобрался :P
Мать у меня PCPartner
Specification : -
Processor
- AMD® Athlon® & Duron® (K7) (200MHz DDR Front Side Bus) (Socket A).
Chip Set
- VIA® KT-133 + 686A (K133ASA-911).
- VIA® KT-133 + 686B (K133ASA-B911).
BIOS
- 2M Flash EPROM (Support PnP, APM, ACPI, ATAPI, DMI).
- IDE AUTO LBA Mode Supports HDDs over 8.4GB.
- Trend Micro ChipAway Virus Protection.
Cache
- L2 Cache is CPU Built-in.
Memory
- Size up to 768MB.
- Three 168-pins DIMMs.
On Board I/O
- Support Two PCI Enhanced IDEs PIO Mode 3, Mode 4 and Ultra DMA 33/66/100
Channels (Optional Ultra DMA 66/100 Cable & Ultra DMA100 for K133ASA-B911
only). Twin Headers for Four IDE Devices Including IDE HDDs and CDROMs.
- Support Two FDDs of 360KB, 720KB, 1.2MB, 1.44MB or 2.88MB.
- One ECP/EPP Parallel Port, Two 16550A UART Serial Ports, Four USB Ports (Two
USB Ports by Optional Adapter Cable), PS/2 Mouse Port, PS/2 Keyboard Port.
On Board Sound
- Integrated AC97 Controller with Standard AC97 Codec.
- PnP, Full-Duplex, Sound Blaster 16 Compatible, Direct Sound Ready.
- Line-in, Line-out, Mic-in and MIDI/Game Port .
Hardware Monitoring (Optional)
- Voltage, Temperature, Fan Speed Monitoring, CPU Over Heat Protection.
Expansion Slot
- One ISA Bus Slots (One PCI Shared Slot).
- Five PCI Bus Slots (One ISA Shared Slot).
- One Accelerated Graphics Port (AGP).
- One Audio Modem Riser (AMR).
Plug and Play
- Plug and Play Specification 1.1.
- Plug and Play for DOS®, Windows® 3.x, and Windows® 95.
PC97/98
- PC97/98 Ready, PC99 Color Connector.
Power Management
- Support SMM, APM and ACPI.
- Comply to Energy Star ?Green PC? Program.
- Supports Modem Ring-in Wake Up.
PCI
- PCI 2.1.
AGP
- AGP 2.0 / 1.0.
VRM
- On Board VRM.
Battery
- On-board Lithium Battery.
Others
- CPU Frequency Multiplier Jumperless (Optional).
- Alarm Wake-up
- Bundle ?PC-cillin? Anti Virus Software
Board Size
- 218mm x 305mm, ATX Form Factor.
нашел последнию версию прошивки ,
На всякий случай прошил хот свапом на бругую флешку
теперь есть желание покавырять патчером , по поводу чего собственно вопрос КАК
Т.Е. 4.23 последняя версия Если нет то можно ссылочку
поменяется ли название CPU и как прозвонить тот самый злополучный кондер на RESET , дающий задержку 100nS.
и фаил ROM_BY__.WWW и есть тот самый
пропадченый
биос
PC Simpron и дурик в Epox и кривобайте стартуют так что это мать виновата
и фаил
ROM_BY__.WWW
и есть тот самыйPC Simpron и дурик в Epox и кривобайте стартуют так что это мать виновата![roll](http://bios.rom.by/img/smiles/icon_rolleyes.gif)
