IT8892E is a single-function PCI Express to PCI bridge, which is compliant with the PCI Express Base Specification Revision 1.1, PCI Local Bus Specification Revision 3.0 and PCI Express to PCI/PCI-X Bridge Specification Revision 1.0. The PCI Express interface supports a x1 lane configuration, and enables the bridge to provide high-performance operation of the data transfer rate up to 250MB/s. The PCI bus interface supports 32-bit and can operate at up to 66 MHz-это все что смог нарыть
