You re right, R221 is valid 2,2KΩ
10 Апр 2016 - 08:07
Aleksey_56
2511
166.67
You're right, R221 is valid 2,2KΩ
HIS 7870 R1800
Yes I found that out on a harder
APW7165 happen both from 0.8V by reference voltage,
On the other side there is APW7165 which
AM113, for an example it is possible
yes, thanks for checking that for me I think
Can I ask for value of another resistor,
Ok, sorry. I soldered resistor but I still have
Better write in English, you will be
спасибо большое Я поставил резистор, но, к сожалению, похоже,
150Ω
