Better write in English, you will be
9 Апр 2016 - 15:20
Aleksey_56
2511
166.67
Better write in English, you will be easier to understand.
HIS 7870 R1800
Yes I found that out on a harder
APW7165 happen both from 0.8V by reference voltage,
On the other side there is APW7165 which
AM113, for an example it is possible
yes, thanks for checking that for me I think
You're right, R221 is valid 2,2KΩ
Can I ask for value of another resistor,
Ok, sorry. I soldered resistor but I still have
спасибо большое Я поставил резистор, но, к сожалению, похоже,
150Ω
