Прошиться на TL-WR54xG V6_071123 не получается, возможно потому, что о текущей прошивке написано:
Support for SST flash; New web v4 platform; Note: 1. If the router has been upgraded to this version, it can NOT be downgraded to any older version;
2. All the settings will be lost after the upgrade, the LAN IP address will be set to default 192.168.1.1;
3. The backup configuration files which generated on the older firmware is not suitable for this version. ПРИМЕЧАНИЕ for TL-WR54xG v4 and v6
Так как все-таки перейти на на TL-WR54xG V6_071123 ?
Note:
