4 -- TXD -- Analog Input -- Thermal diode temperature sensing input ------- Trigger voltage (V) 0.556 (min) 0.566 (nom) 0.576 (max) 5 -- TXR -- Analog Input -- Thermistor temperature sensing input ------- Trigger voltage (V) 0.470 (min) 0.500 (nom) 0.530 (max) 7 -- VREF -- Analog Output -- Reference voltage output ------- Output voltage 3.75 V
Programmable trigger temperature by external resister
Никак.
