I measured resistence between GND and all other
I measured resistence between GND and all other contacts on PWR connector. here is result: +12=22.2K; +5=1.1k ; +3=1.91k; PWR_OK=13.14Mom !?(can this be a problem?) ;5VSB=680om ; PS_ON=1.67k ; -12V=7.24Mom ; -5V=INFINITE
If it`s is not trouble for you, can u tell me in short ,what can i learn from this resistence values?What should they be in normal?
Since I have USB shortcut with VIA southbridge can I use metod "отжига"?
I did`nt find from where is 0.16v on front panel PS_ON is coming.It`s not from IT8705F. Can it be from "юм"?
