1) This parameter is used to set startup multtiplier for mobile Athlon XP processors, both "native" or L5-modded. If your CPU does not have PowerNow functions enabled - this parameter is of no use to you.
3) It can be set to any value lower than 16*133. Again - only if you have PowerNow enabled by closng L5 bridge. Look here for details.
