Vsem privet, ja polyak. Ja govoryu pa ruskij srednenko.
Ok, I'm not good at this, let's just switch to english
The problem I got is - upgrading my oldie notebook BIOS. I want to have bigger HDD support, that is only possible with r1.17 BIOS. I have Mitac M722-H, but the new BIOS file is for M722. The only difference in models is LCD manufacturer. After flashing everything works fine, expect LCD - that is just black (not lighting up), not even blink. I operate now with external monitor. I tried switching BIOS settings (setting VGA output to external / LCD / both) and nothing helps, also tried a combination of Fn+5 and Fn+11 in many ways, and it didn't help. I have a copy of older BIOS of course. I have opened BIOS files I have got in hex editor and realized there are some differences between r1.03 M722-H and r1.16, r1.16L, r1.17 in header that is starting with "VGABIOS". I bet this causes the problem. Is anyone on this board a "Insyde BIOS guru" ? Is this even technically possible to copy a VGA BIOS block from r1.03 to a r1.17, and would it flash correctly ? I have attached all BIOS'es I have mentioned in this post.
Regards, Damian.
Вложение | Размер |
M722Hsys103.zip | 220.1 КБ |
R116.rar | 185.6 КБ |
M722_116LBIOS.zip | 221.9 КБ |
r117.zip | 224.61 КБ |
You must try to use EZH2O
forum.ixbt.com/topic.cgi?id=17:35660:4483#4483
Дрессируем коров
forums.mydigitallife.info/threads/13194-Tool-to-Insert-Replace-SLIC-in-Pho...
Дрессируем коров
Both programs doesn't support this BIOS.
I guess this is a real challenge
One thing I forgot to say, M722-H uses MIFLASH for flashing (but accepts M722 BIOS files without any problems) instead of FLASHIT.
The chip is: SST 29EE020
I also noticed that r1.03 is the only one with "BootBlock":
And back to r1.03, POST screen:
