GA-MA770-DS3 REV.2.0
When MOBO is turned on I got POST 09. I tried to find what is POST 09 but in literature its "RESERVED"!?
CPU, RAM, CHIPSET voltages are OK!
I heated NORTH and SOUTH bridges with no result. SIO is ITE IT8720F 0827-FXS (I don`t have another one to trie chanige).
Ideas?
Аватар пользователя Max
BIOS прошили?
Begin with BIOS update
Может по-русски непонемает
Аватар пользователя Jega
EPROM is MX25L8005M2C-15G and I tried to flash it by hotswap on ASUS M2N68-AM SE2. Then I figured up that BIOS is AWARD and I need proper flasher. I tried with AWDFLASH v8.83 and it can`t recognise this EPROM. What flasher (or it`s revision) can do this?
AFUDOS(v.2.29).
I tried AFUDOS229ES with /n switch, but i got message ROM FILE BOOT BLOCK IS NOT VALID. Do you know what switch I must use to avoid this message?
