Пасибо что утешили ! вот только шим-контроллер не могу наити это вроде hip3019bcb но найти ничего не могу ПОМОГИТЕ пожалуйста!1
Добавлено спустя 37 минут 19 секунд:
Ой извиняюсь hip6019bcb на сайте написано :
Description
The HIP6019B provides the power control and protection for four output voltages in high-performance microprocessor and computer applications. The IC integrates two PWM controllers, a linear regulator and a linear controller as well as the monitoring and protection functions into a single 28 lead SOIC package. One PWM controller regulates the microprocessor core voltage with a synchronous-rectified buck converter, while the second PWM controller supplies the computer’s 3.3V power with a standard buck converter. The linear controller regulates power for the GTL bus and the linear regulator provides power for the clock driver circuits.
The HIP6019B includes an Intel-compatible, TTL 5-input digital-to-analog converter (DAC) that adjusts the core PWM output voltage from 2.1VDC to 3.5VDC in 0.1V increments and from 1.3VDC to 2.05VDC in 0.05V steps. The precision reference and voltage-mode control provide ±1% static regulation. The second PWM controller is user-adjustable for output levels between 3.0V and 3.5V with ±2% accuracy. The adjustable linear regulator uses an internal pass device to provide 2.5V ±2.5%. The adjustable linear controller drives an external N-Channel MOSFET to provide 1.5V ±2.5%.
The HIP6019B monitors all the output voltages. A single Power Good signal is issued when the core is within ±10% of the DAC setting and the other levels are above their under- voltage levels. Additional built-in over-voltage protection for the core output uses the lower MOSFET to prevent output voltages above 115% of the DAC setting. The PWM controller’s over-current functions monitor the output current by sensing the voltage drop across the upper MOSFET’s rDS(ON), eliminating the need for a current sensing resistor.
Key Features
Provides 4 Regulated Voltages
Microprocessor Core, I/O, Clock Chip and GTL Bus
Drives N-Channel MOSFETs
Operates from +5V and +12V Inputs
Simple Single-Loop Control Designs
Voltage-Mode PWM Control
Fast Transient Response
High-Bandwidth Error Amplifiers
Full 0% to 100% Duty Ratios
Excellent Output Voltage Regulation
Core PWM Output: ±1% Over Temperature
I/O PWM Output: ±2% Over Temperature
Other Outputs: ±2.5% Over Temperature
TTL-Compatible 5-Bit Digital-to-Analog Core Output Voltage Selection
Wide Range 1.3VDC to 3.5VDC
0.1V Steps 2.1VDC to 3.5VDC
0.05V Steps 1.3VDC to 2.05VDC
Power-Good Output Voltage Monitor
Microprocessor Core Voltage Protection Against Shorted MOSFET
Over-Voltage and Over-Current Fault Monitors
Does Not Require Extra Current Sensing Element, Uses MOSFET’s rDS(ON)
Small Converter Size
Constant Frequency Operation
200kHz Free-Running Oscillator; Programmable from 50kHz to 1MHz
Pb-Free Available (RoHS Compliant)
Related Documentation
Application Note(s):
Total Power Conversion Solutions for Computer Motherboards Using HIP6017, HIP6019 Controller Ics
Datasheet(s):
Advanced Dual PWM and Dual Linear Power Control
Other:
28 Lead Wide Body Small Outline Plastic Package (JEDEC MS-013-AE Issue C)
Parametric Data
VIN (min) (V) 5
VIN (max) (V) 5
VOUT1 (min) (V) 1.3
VOUT1 (max) (V) 3.5
VOUT2 (V) Adj.
VOUT3 (V) Adj.
VOUT4 (V) Adj.
IOUT1 (A) 25
Какие выводы ???как я понял вплоть до 1.3V и Тулик всё таки заработает???
Description
Key Features
Datasheet(s):
Other:
Parametric Data
VIN (min) (V) 5
VIN (max) (V) 5
VOUT1 (min) (V) 1.3
VOUT1 (max) (V) 3.5
VOUT2 (V) Adj.
VOUT3 (V) Adj.
VOUT4 (V) Adj.
IOUT1 (A) 25
