To sh2cer: Уважаемый, читайте доку, а
To sh2cer: Уважаемый, читайте доку, а не придумывайте отсебятину.
To NeleGal: Хз, по идее должно работать. Во всяком случае здесь asrock.com/support/AGI8X_LIST/p4i65gv.htm
5200-ые встречаются. Надо просто подбирать карту, видимо...
Ну, и курить мануал
To install the system with an add-on AGP VGA card, you must make
sure to install the driver of add-on AGP VGA card before you install
the onboard VGA driver. If the onboard VGA driver has already been
installed before you install the add-on AGP VGA card, the system will
automatically set the onboard VGA as the primary graphics adapter. In
that case, if you want to install the add-on AGP VGA card, you need
to remove the onboard VGA driver first, and then install the add-on
AGP VGA card and its driver. For the detailed instruction, please refer
to the documents in the Support CD, “AGI Slot Installation Guide (for
Windows 2000)” and “AGI Slot Installation Guide (for Windows XP)”,
which are located in the folder at the following path:
..\ Easy Dual Monitor
P.S. Назовите тему поприличнее (т.е. информативно), а?
Help!!!
