Important Update to Award BIOS Code Injection
Important Update to Award BIOS Code Injection Article
OK, let me clarify, there is nothing wrong with the main concept explained in the article, i.e. the method used to inject new code into Award BIOS. But, there is something that can mislead people in the particular implementation explained there in the last section (Possible Downside and Its Workaround). I've made a "critical update" to address the issue in the latest version of the article in the following link:
To summarise, the issue is: in the original article I've claimed that the bug due to the race condition (in the sample injected-code) has been addressed, whereas, further experiment don't say so. Thus, I've carried out further experiments last week to find out the problem and has come-up with a thoroughly tested solution, i.e. a reworked patch.
well, I'll just paste the relevant code here to clarify.
#The sample injected-code in the original article (nasm syntax):
;---------------- BEGIN TWEAK.ASM --------------------------------------------------------------
BITS 16 ;just to make sure nasm prefix 66 to 32 bit instructions, we're assuming the uP
        ;is in 16 bits mode up to this point (from the boot state)
  section   .text
start:
	pushf
	push eax
	push dx
	mov eax,ioq_reg	 ;patch the ioq register of the chipset
	mov dx,in_port
	out dx,eax
	mov dx,out_port
	in  eax,dx
	or  eax,ioq_mask
	out dx,eax
	mov eax,dram_reg ;patch the DRAM controller of the chipset,
	mov dx,in_port	 ;i.e. the interleaving part
	out dx,eax
	mov dx,out_port
	in  eax,dx
	or  eax,dram_mask
	out dx,eax
	mov eax,bank_reg ;Allow pages of different bank to be active simultanoeusly
	mov dx,in_port
	out dx,eax
	mov dx,out_port
	in  eax,dx
	or  eax,bank_mask
	out dx,eax
	mov eax,tlb_reg	 ;Activate Fast TLB lookup
	mov dx,in_port
	out dx,eax
	mov dx,out_port
	in  eax,dx
	or  eax,tlb_mask
	out dx,eax
	pop dx
	pop eax
	popf
	clc		 ;indicate that this POST routine successful
	retn		 ;return near to the header of the rom file
  section .data
  in_port   equ 0cf8h
  out_port  equ 0cfch
  dram_mask equ 00020202h
  dram_reg  equ 80000064h
  ioq_mask  equ 00000080h
  ioq_reg   equ 80000050h
  bank_mask equ 20000840h
  bank_reg  equ 80000068h
  tlb_mask  equ 00000008h
  tlb_reg   equ 8000006ch
;---------------- END TWEAK.ASM --------------------------------------------------------------
This code causes the system to hang in certain circumstances.
#The reworked injected-code (fasm syntax)
;------------------------------ file: mem_optimize.asm -----------------------------------
use16
start:
        pushf
        cli
        mov  cx, 0x50           ;patch the ioq register of the chipset
        call Read_PCI_Bus0_Byte
        or   al, 0x80
        mov  cx, 0x50
        call Write_PCI_Bus0_Byte
        mov  cx, 0x64           ;DRAM Bank 0/1 Interleave = 4-way
        or   al, 2
        mov  cx, 0x64
        mov  cx, 0x65           ;DRAM Bank 2/3 Interleave = 4-way
        or   al, 2
        mov  cx, 0x65
        mov  cx, 0x66           ;DRAM Bank 4/5 Interleave = 4-way
        or   al, 2
        mov  cx, 0x66
        mov  cx, 0x67           ;DRAM Bank 6/7 Interleave = 4-way
        or   al, 2
        mov  cx, 0x67
        mov  cx, 0x68           ;Allow pages of different bank to be active simultanoeusly
        or   al, 0x44
        mov  cx, 0x68
        mov  cx, 0x69           ;Fast DRAM Precharge for Different Bank
        or   al, 0x8
        mov  cx, 0x69
        mov  cx, 0x6C           ;Activate Fast TLB lookup
        or   al, 0x8
        mov  cx, 0x6C
        popf
;-- Read_PCI_Byte__ --
;in: cx = dev_func_offset_addr
;out: al = reg_value
Read_PCI_Bus0_Byte:
        mov   ax, 8000h
        shl   eax, 10h
        mov   ax, cx
        and   al, 0FCh
        mov   dx, 0CF8h
        out   dx, eax
        mov   dl, 0FCh ; '?'
        mov   al, cl
        and   al, 3
        add   dl, al
        in    al, dx
        retn
;-- Write_Bus0_Byte --
;in: cx = dev_func_offset addr
;al = reg_value to write
Write_PCI_Bus0_Byte:
        xchg  ax, cx
        shl   ecx, 10h
        xchg  ax, cx
        mov   ax, 8000h
        shl   eax, 10h
        mov   ax, cx
        and   al, 0FCh
        mov   dx, 0CF8h
        out   dx, eax
        add   dl, 4
        or    dl, cl
        mov   eax, ecx
        shr   eax, 10h
        out   dx, al
        retn
This new patch (injected-code) is working flawlessly during the "patch-integrity" test, i.e. more than a hundred boot-reboot cycle wink
sorry for the inconvenience.
greetz,
Pinczakko
