Нашел решение на буржуазном форуме . http://www.rcgroups.com/forums/showthread.php?t=1005309 page=64#post19639890 Finally
rcgroups.com/forums/showthread.php?t=1005309&page=64#post19639890
"Finally after several attempts to get the supply to hold voltage with load I believe I have the answer. Instead of jumpering pins 30, 31 and 34 together just jumper 34 to 31 and tie pin 30 to +12V. So far I can now load up to 45 amps and the output drops just 100mv (12.9V to 12.8V). I do believe I will have a double gin and tonic to celebrate. I had almost given up and tossed the supply. Now I hope I can get more as I believe this is one nice compact supply capable of delivering 65 amps. I plan to series up a couple for 24V which be a piece of cake seeing as the negative is not tied to chassis ground."
Еще одно интересное решение для аналогичного блока ( DPS-700EB), поднимает до 15 В
rcgroups.com/forums/showpost.php?p=18908291&postcount=844
P.S. Очень интересный ресур там кстати
Вот, еще там нашел. Буду пробовать вечером
rcgroups.com/forums/showthread.php?t=1005309&highlight=dps+800gb&page=93
I think pins #32 and #33 (at outer edge on top and bottom) are good candidates to try, tho I haven't seen these pins mentioned earlier in the posts about DPS-800GB.
When PS is on, pin#32 floats just a little under Vout, and the other one #33 just slightly above 0V (0.08V).
About pin #30: When disconnected from +12Vout, the output decreases,
also with a resistor to +V as well as GND.
The highest output is achieved with a jumper wire staight from pin#30 to +12Vout.
Edit:
After some experimenting, I found the following circuit achieves an increased, and adjustable output Voltage. With my DPS-800GB PS, I could adjust the +Vout from 12,8 to 14,4V. At 14.45V the OVP kicks in.
Regulation is still outstanding (+/- 100mV from zero to full 85Amp load at 13,6V)
dps-800gb-a-variable_output.png 168.38 КБ
Блок питания DPS-800GB, повысить выходное напряжени
  • Всем привет. Вроде сделал его, поиграл резисторами вывел
  • У меня его еще нет, я его в
  • Так у него сзади разъем. Вы чего, и
  • 220в на какие контакты подключать?
  • Нда, вот и бред попер :).
  • Так получается от АКБ работает блок питания? Я
  • Если у вас проблемы с чтением, то
  • Но я извиняюсь тут, я как новичок. Но я
  • Оно у вас и так стабильное
  • Дело не в повышении, может я не так
  • Забавно-дебильный вопрос в свете желания повысить выходное напряжение:). Читать
  • Притом что, я когда открывал тему, задал точно
  • Всем привет. Парни если не сюда написал то
  • UAM это немного другой блок, по распиновке и
  • Pandel, спасибо. Там двухсторонняя плата с
  • Как нести чушь - так ничего
  • Где то читал что 4 слоя. И плата
  • Нда, поглядеть на просвет и увидеть
  • Да там плата черт ногу сломит, скорее всего
  • Один компаратор, как правило, обеспечивает отработку
  • и правда бедный(( либо полностью вырубается защита, либо
  • Бедный БП :D.
  • К сожалению никогда не занимался ремонтом блоков, и
  • Интересно, когда на Pandel снизойдет
  • Разобрался как убрать защиту от перенапряжения на блоке
  • Похоже как повысить напряжение - понятно, но
  • Кто нибудь знает как понять напряжение до 15в
  • Надеюсь это не нарушение ссылочку кинуть? Уже 7,19 баксов
  • где вы такие только находите кажись по
  • Именно для этих целей ребята, что мне
  • ... ага - за морем телушка полушка, да
  • Проверил последнее решение. Только резик поставил вместо 6.8
  • Спасибо, что отписались. Полезная инфа.
  • Нашел решение на буржуазном форуме . http://www.rcgroups.com/forums/showthread.php?t=1005309&page=64#post19639890 "Finally after several
