BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses|
Found 2Mbit Award BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support : -> fixed.
Mobile AMD Multipl-r adding : -> fixed.
Adding AMDK7NOW! support : -> fixed.
2. XP frequency : -> fixed.
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : found, but Unknown format!
14.Set "Y" as default on exit: not found.
Tweak options addinng:
1a.CPU MSRs Init (s2k2bp.ini): -> fixed.
Bus Disconnect Support : -> fixed.
Display Features adding : -> fixed.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 47.7%
Adding start.tmp 87.5%
Adding tweak.tmp 45.2%
(c)2002-2004 apple_rom, www.ROM.by
Проц Thorton 2400+, замобилен. После прошивки все фичи работают, множитель меняется во всех направлениях, глюков не замечено. :P
Epox 8K3AP
epox.ru/downloads.php?file=/data/download/bios/8K3A3916.zip
