My AMI bios does not have the 32 GB hard disk bug... But it does have the 65535 MB barrier...
I believe in next version or so you will be targeting this issue as well..
Thanx for this great tool
output when I patched my bios
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses|
Found 4Mbit AMI BIOS!
!! Module Manipulation Successful !!
4. 32Gb-problem : not found.
Tweak options addinng:
(c)2002-2004 apple_rom, www.ROM.by
Thanx
