That is a great program.
I made a liittle modification to SST.pas to possibly flash 49LF040B, since 8 registers had been added to write protect the blocks.
Function SSTIdChip( DevId : Byte; Var CInfo : ChipInfo ) : Boolean; Far;
Var X : Byte; {Verify LPC memory mapping}
Begin ................
$50 : Begin {v1.47re} Flags := 0; {sector mode} PgSize := 128; {'page' size, program 128 bytes at a time} Progr := AMDSecProg; Erase := AMDSecErase; Sectors[ 0, 0 ] := 128; {128 x 4k} Sectors[ 0, 1 ] := 32; Size := 512; Name := ConstPtr( '49LF040B/3V (LPC)' ); FOMemB($FFB80002, 0); FOMemB($FFB90002, 0); FOMemB($FFBA0002, 0); FOMemB($FFBB0002, 0); FOMemB($FFBC0002, 0); FOMemB($FFBD0002, 0); FOMemB($FFBE0002, 0); FOMemB($FFBF0002, 0); {Verify LPC memory mapping} End;
Var
End;
