Доброго времени суток.
Вообщем вопрос>>
Есть вот такой винт>
На наклейке:
FUJITSU
MODEL:MPG3409AH -EF ID: YTIM
PART NO: CA05762-B54200EF
SER NO: VL03T17032RK DATE: 2001-07
При включении компа раскручивается, но не видется в БИОСЕ!!!
Не видит: MHDD, HDDL, Fujitsu EXPLORER!!!
Видит только>>>
PCHDD.........
Log started...
Secondary address selected - base port set to:170
PCI BIOS version 2.10 found. Total : 2 PCI bus present
North Bridge found VID: 8086 DID: 7190
South Bridge found VID: 8086 DID: 7110
IDENTIFY_DEVICE ATA Rev 3.7b Dump:
00 B 1111111001011000
- General configuration bit-significant information:
15 0=ATA device / 1=ATAPI device
[14-8] Obsolete
7 1=removable media device
6 1=not removable controller and/or device
[5:1] Obsolete
0 Reserved
01 D 65112 - Number of logical cylinder
02 H FE58 - Reserved
03 D 65112 - Number of logical heads
04 H FE58 - Obsolete
05 H FE58 - Obsolete
06 D 65112 - Number of logical sectors per logical track
07 H FE58 - Vendor specific
08 H FE58 - Vendor specific
09 H FE58 - Vendor specific
0A S _X_X_X_X_X_X_X_X_X_X_
- Serial number (20 ASCII characters)
14 H FE58 - Obsolete
15 H FE58 - Obsolete
16 D 65112 - Number of vendor specific bytes available on READ/WRITE LONG
17 S _X_X_X_X_
- Firmware revision (8 ASCII characters)
1B S _X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_
- Model number (40 ASCII characters)
2F H FE58 - [15:8 ] Vendor specific
[7:0] 00h Reserved, 01h-ffh Maximum number of sectors that
can be transferred per interrupt on READ/WRITE MULTIPLE
commands
30 H FE58 - Reserved
31 B 1111111001011000
- Capabilities
[15:14] Reserved
13 1=Standby timer values as specified in this standard
are supported
0=Standby timer values are vendor specific
12 Reserved (for advanced transfer mode)
11 1=IORDY supported / 0=IORDY may be supported
10 1=IORDY can be disabled
9 Obsolete
8 Obsolete
[7:0] Vendor specific
32 H FE58 - Reserved
Отсюда понял что сбиты модули: 0A S, 17 S, 1B S !!!
VICTORIA FUJITSU (Простая тоже винт не видит!!!)
Init drive...... OK
ПАСПОРТ!!! почемуто не отдает модель и FirmWare (Ну наверно из-за битых модулей)
Model: X X X X X X X X X X X X X X X X X X X X ;
f/w: X X X X
S/N: X X X X X X X X X X;
LBAs: 156764504
LBA size: 76545 Mb; CHS: 2392/2392/2392/253028 Mb----это тоже не верно винт же 40Г
SMART: Not supported
Support: CHS,DMA(MWDMA2,UDMA6),APM,SMS
Security: Not supported.
Чтение модулей из служебной зоны.
Список поддерживаемых моделей:
1. MPG_AT #1. TAU (r/o)
2. MPG_AH #2. MHK_AT
3. MPF_AH #3. MHM_AT
4. MPF_AT #4. MHN_AT
5. MPE_AT #5. MHR_AT
6. MPE_AE #6. MHS_AT
7. MPD_AT #7. MHT_AT
8. MPC_AT #8. MHH_AT
9. MPB_AT #9. Reserved
0. UNIVERSAL #0. Mod 20h
_ Set valid mode...... OK
_ Read CP_1........ OK----ЗДЕСЬ ЗАВИСАЕТ!!!
RECOVERY TOOL 2.02А
ВИСНЕТ НА.........
NOW LOADING
PLEASE WAIT A FEW MINUTES
Пожалуйста подскажите что можно сделать! если залить новые модули, то где их брать???
Заранее благодарен!!!
модули брать отсюда
hdd-recovery.narod.ru/_fujitsu/fujitsu.htm
я всё время там беру, если в своих не нахожу
электричество - это наука о контактах!
с уважением. Пьяный Мастер.
брать у Киреева на сайте или на асялабе, поднимать цирус мыть, в кернеле лить нужное с конца списка, ресетить после каждого модуля(для верности). это один из простых способов, их множество. =D>
OK Прошивки закачал, вот только вопр>>> их там несколько штук, а какую лить то?
P.S. не ругайте сильно :oops: такими вещами еще не занимался, а 40Г жалко! так что если поможете, мож и подниму винт, да и опит получу
С УВАЖЕНИЕМ
USer интересно как он на блины в кернеле зальёт, если они в кернеле не раскручиваются?
MOZAS в правом нижнем углу наклеки на гермоблоке версия фирмвари вида
примерно такого "782-80С2" вот посмотри какая у тебя. из той и лей.
лить действительно лучше с последнего, я после каждого модуля делаю рестарт винта тулблером на хвосте питания.
мыть надо, поднимать необязательно. тут каждый изобретает свою жижку и технологию (как лак для скрипок) и никому не говорит состав. я свою сделал, состав не скажу. после промывания в ней под цирозом логики никаких остатков флюса. поднимал для проверки несколько...
To hairs
имеется ввиду файла или чего?
это как?
мыть понял! а поднимать всмысле? по части жижки-читал что просто спиртом!
:oops: :oops: :oops:
С УВАЖЕНИЕМ
значит начинаем сначала.
кладёшь винт платой вниз, разъёмом ИДЕ от себя. .в верхней части, ближайшей стороне к разъёму ищем большую белую наклейку размером 60х40 мм. на ней должен быть серийнйё номер (SER. NO) и штрих код.
ищем на этой наклейке самую нижнюю надпись, состоящую из восьми символов четвёртый из которых по-любому дэфис (тире).
что там написано?
лить с последнего слетевшего номера модуля!
правда надо пересчитать в десятичный вид их номера.( я уже не помню как это ...)
поскольку если ты брал с данного мною урла, то там они все в десятичном.
а ещё для работы с фуджами поищи coolstuff (ой меня сейчас взгреют!!!)
если есть вопросы , то лучше в аську или хотя бы в личку
hairs а ты попробуй. и глядишь получиться начинать надо ессно с мозгов флехи, а потом уже и остальное прирастет.
Народ а цирус обязательно отпаивать??? или можно промто модули прошить?
С УВАЖЕНИЕМ
можно и промыть, в спирту и растворе щавелевой к-ты. на время поможет.
а чего пробовать? я и так знаю что в кернеле доступа к блинвари нету.
только к содержимому ПЗУ.
уж за сотню фуджиков восстановил
