they are similar http://www.rom.by/forum/Moshchnye_tranzistory_primenjaemye_v_BP_Podbor_i_zamena?page=12 between pin 1 to
1 Сен 2014 - 22:15
8857
1027.43
Its not a NCP1203 , its a NCP1200D60
they are similar
ALso the TNY267 has different pins , can it do the job ?
between pin 1 to pin 2 capasitor 0,1uF
Pin 5 instead 8N80C drain
Pin 7 instead 8N80C source
Pin 4 connect to pin 4 optocoupler
ThermaltakeToughpower 1500W TP-1500M - не работает дежурка на 200D6
you want more info ? 6
нда, ну там есть варианты
Leviafan, не пойдет. Еще ШИМку питать
Thanks alot for your help guys , I
you will to sell ? my email :
IMHO... My be stand-by transformer is possible to
All, without IS and transistor.
what parts are left on that psu ?
No, that PSU was disassembled for using
No problem . Its not a NCP1203 ,
I do not want to give personalized
will you sell your psu ? If I
БП починить не удалось. Скорее всего было КЗ в
Do you have his email so I can
History is silent about it.
Yea short ( 2 - 3 ohms) .
No. Short (0-2 ohm) or low resistance?
Yes I checked them and they seem to
new2013, может быть, что только NCP1200D6
Hi , I used google translator to translate
, переводчик плохой. :( Непонятно. 200D6 = NCP1200D6
Привет, у меня такая же проблема с моим
Тут параллельно две аналогичные темы. http://www.rom.by/forum/BP_tyunera_Topfield_TF4000fi http://www.rom.by/forum/Pomogite_razobratsya_s_problemnym_blokom_pitaniya
they are similar
