Подключил. вот что написало: DM1000 Bootloader XE40 ----------------- A-PHY GUID: 000d6c04
Подключил.
вот что написало:
A-PHY
GUID: 000d6c04'00dd5957
HWID: 00000083
HWVS: 00000001
BLDS: 00000000
Bootloader: CRC ok! Id=00000001, V=00002805, 20040330-025909UT
Debugger: invalid
Image: CRC ok! Id=00000000, V=00000000, 20070713-080440UT
CnE: CRC ok! Id=00000000, V=00000000, 20070713-080440UT
Press Ctrl-A to avoid starting image!
Testing RAM address 0x10000000 length 0x00080000. Ok.
1) Download Image and Config (CnE)
2) Download Image only
3) Do RAM test
4) Start Image
5) Start 1394 Debugger
6) Mark Image as invalid
7) Print Flash Info
8) Set Start Mode
Bootloader (return=help) >
3) Do RAM test
4) Start Image
7) Print Flash Info
8) Set Start Mode
