Вот пример кода из Award-Phoenix: Функция поиска PCI устройства
Функция поиска PCI устройства по классу
_F000:EB7C
_F000:EB7C                   ; =============== S U B R O U T I N E =======================================
_F000:EB7C
_F000:EB7C                   ; return:
_F000:EB7C                   ;   found device in ecx,
_F000:EB7C                   ;   error in carry flag,
_F000:EB7C                   ;   return at the <bx> address (jmp bx)
_F000:EB7C
_F000:EB7C                   ; __int32 __usercall PCI_FindByClass<ecx>(unsigned __int16 class<ax>)
_F000:EB7C                   PCI_FindByClass proc near                                   ; CODE XREF: sub_FE414+9j
_F000:EB7C        ; sub_FE543+9j ...
_F000:EB7C 8B C8                             mov     cx, ax
_F000:EB7E 66 B8 08 00 00 80                 mov     eax, 80000008h                      ; 0:0.0 - with offset 8
_F000:EB7E        ;
_F000:EB7E        ; RID - Revision Identification
_F000:EB7E        ;
_F000:EB7E
_F000:EB84
_F000:EB84                   pci_read_loop:                                              ; CODE XREF: PCI_FindByClass+4Fj
_F000:EB84 BA F8 0C                          mov     dx, PCI_ADDRESS_PORT
_F000:EB87 66 EF                             out     dx, eax
_F000:EB89 BA FC 0C                          mov     dx, PCI_DATA_PORT
_F000:EB8C 66 8B F8                          mov     edi, eax
_F000:EB8F 66 ED                             in      eax, dx
_F000:EB91 66 C1 E8 10                       shr     eax, 16                             ; check SubClass and BaseClass
_F000:EB95 3B C1                             cmp     ax, cx                              ; Compare Two Operands
_F000:EB97 74 37                             jz      short return_carry_0                ; Jump if Zero (ZF=1)
_F000:EB97
_F000:EB99 66 8B C7                          mov     eax, edi
_F000:EB9C A9 F0 07                          test    ax, 11111110000b                    ; function 7 offset 0xF0
_F000:EB9F 75 19                             jnz     short increment                     ; Jump if Not Zero (ZF=0)
_F000:EB9F
_F000:EBA1 83 C0 04                          add     ax, 4                               ; Add
_F000:EBA4 BA F8 0C                          mov     dx, PCI_ADDRESS_PORT
_F000:EBA7 66 EF                             out     dx, eax
_F000:EBA9 BA FC 0C                          mov     dx, PCI_DATA_PORT
_F000:EBAC 66 ED                             in      eax, dx
_F000:EBAE 66 C1 E8 10                       shr     eax, 16                             ; Shift Logical Right
_F000:EBB2 3D 80 00                          cmp     ax, 10000000b                       ; Compare Two Operands
_F000:EBB5 75 08                             jnz     short next_part                     ; Jump if Not Zero (ZF=0)
_F000:EBB5
_F000:EBB7 66 8B C7                          mov     eax, edi
_F000:EBB7
_F000:EBBA
_F000:EBBA                   increment:                                                  ; CODE XREF: PCI_FindByClass+23j
_F000:EBBA 05 00 01                          add     ax, 256                             ; Add
_F000:EBBD EB 09                             jmp     short check_if_all_read             ; Jump
_F000:EBBD
_F000:EBBF                   ; ---------------------------------------------------------------------------
_F000:EBBF
_F000:EBBF                   next_part:                                                  ; CODE XREF: PCI_FindByClass+39j
_F000:EBBF 66 8B C7                          mov     eax, edi
_F000:EBC2 66 05 00 08 00 00                 add     eax, 2048                           ; Add
_F000:EBC2
_F000:EBC8
_F000:EBC8                   check_if_all_read:                                          ; CODE XREF: PCI_FindByClass+41j
_F000:EBC8 3D 08 FF                          cmp     ax, 0FF08h                          ; Compare Two Operands
_F000:EBCB 76 B7                             jbe     short pci_read_loop                 ; Jump if Below or Equal (CF=1 | ZF=1)
_F000:EBCB
_F000:EBCD F9                                stc                                         ; Set Carry Flag
_F000:EBCE EB 04                             jmp     short return                        ; Jump
_F000:EBCE
_F000:EBD0                   ; ---------------------------------------------------------------------------
_F000:EBD0
_F000:EBD0                   return_carry_0:                                             ; CODE XREF: PCI_FindByClass+1Bj
_F000:EBD0 66 8B C7                          mov     eax, edi
_F000:EBD3 F8                                clc                                         ; Clear Carry Flag
_F000:EBD3
_F000:EBD4
_F000:EBD4                   return:                                                     ; CODE XREF: PCI_FindByClass+52j
_F000:EBD4 66 8B C8                          mov     ecx, eax
_F000:EBD7 B1 00                             mov     cl, 0
_F000:EBD9 FF E3                             jmp     bx                                  ; jump to 0xED08
_F000:EBD9
_F000:EBD9                   PCI_FindByClass endp
_F000:EBD9
Функции чтения и записи в PCI
_F000:FF4C                   ; =============== S U B R O U T I N E =======================================
_F000:FF4C
_F000:FF4C                   ; Stack Less version, return at the address, written in bx (jmp bx)
_F000:FF4C
_F000:FF4C                   ; __int8 __usercall ReadPCI_byte_SL<ah>(__int32 address<eax>)
_F000:FF4C                   ReadPCI_byte_SL proc near                                   ; CODE XREF: ReadPCI_SL_jmpj
_F000:FF4C        ; ReadPCI_byte_S+7j
_F000:FF4C 66 8B F8                          mov     edi, eax
_F000:FF4F 8B F2                             mov     si, dx
_F000:FF51 66 0F B6 C0                       movzx   eax, al                             ; Move with Zero-Extend
_F000:FF55 66 0F BA E8 1F                    bts     eax, 31                             ; Bit Test and Set
_F000:FF5A 24 FC                             and     al, 0FCh                            ; Logical AND
_F000:FF5C BA F8 0C                          mov     dx, PCI_ADDRESS_PORT
_F000:FF5F 66 EF                             out     dx, eax
_F000:FF61 66 8B C7                          mov     eax, edi
_F000:FF64 8A D0                             mov     dl, al
_F000:FF66 80 CA FC                          or      dl, 0FCh                            ; Logical Inclusive OR
_F000:FF69 86 C4                             xchg    al, ah                              ; Exchange Register/Memory with Register
_F000:FF6B EC                                in      al, dx
_F000:FF6C 86 C4                             xchg    al, ah                              ; Exchange Register/Memory with Register
_F000:FF6E 8B D6                             mov     dx, si
_F000:FF70 FF E3                             jmp     bx                                  ; Indirect Near Jump
_F000:FF70
_F000:FF70                   ReadPCI_byte_SL endp
_F000:FF70
_F000:FF72
_F000:FF72                   ; =============== S U B R O U T I N E =======================================
_F000:FF72
_F000:FF72                   ; Stack Less version, return to the address, written in bx (jmp bx)
_F000:FF72
_F000:FF72                   ; __int32 __cdecl WritePCI_byte_SL(__int32 address, __int32 value)
_F000:FF72                   WritePCI_byte_SL proc near                                  ; CODE XREF: WritePCI_SL_jmpj
_F000:FF72        ; WritePCI_byte_S+7j
_F000:FF72 66 8B F8                          mov     edi, eax
_F000:FF75 8B F2                             mov     si, dx
_F000:FF77 66 0F B6 C0                       movzx   eax, al                             ; Move with Zero-Extend
_F000:FF7B 66 0F BA E8 1F                    bts     eax, 11111b                         ; Bit Test and Set
_F000:FF80 24 FC                             and     al, 0FCh                            ; Logical AND
_F000:FF82 BA F8 0C                          mov     dx, PCI_ADDRESS_PORT
_F000:FF85 66 EF                             out     dx, eax
_F000:FF87 66 8B C7                          mov     eax, edi
_F000:FF8A 8A D0                             mov     dl, al
_F000:FF8C 80 CA FC                          or      dl, 0FCh                            ; Logical Inclusive OR
_F000:FF8F 86 C4                             xchg    al, ah                              ; Exchange Register/Memory with Register
_F000:FF91 EE                                out     dx, al
_F000:FF92 86 C4                             xchg    al, ah                              ; Exchange Register/Memory with Register
_F000:FF94 8B D6                             mov     dx, si
_F000:FF96 FF E3                             jmp     bx                                  ; Indirect Near Jump
_F000:FF96
_F000:FF96                   WritePCI_byte_SL endp
_F000:FF96
_F000:FF98
_F000:FF98                   ; =============== S U B R O U T I N E =======================================
_F000:FF98
_F000:FF98                   ; Stack version
_F000:FF98
_F000:FF98                   ; __int8 __cdecl ReadPCI_byte_S(__int32 address)
_F000:FF98                   ReadPCI_byte_S  proc near
_F000:FF98
_F000:FF98                   address         = dword ptr  2
_F000:FF98
_F000:FF98 53                                push    bx
_F000:FF99 66 57                             push    edi
_F000:FF9B 56                                push    si
_F000:FF9C BB A1 FF                          mov     bx, offset return
_F000:FF9F EB AB                             jmp     short ReadPCI_byte_SL               ; Stack Less version, return at the address, written in bx (jmp bx)
_F000:FF9F
_F000:FFA1                   ; ---------------------------------------------------------------------------
_F000:FFA1
_F000:FFA1                   return:                                                     ; DATA XREF: ReadPCI_byte_S+4o
_F000:FFA1 5E                                pop     si
_F000:FFA2 66 5F                             pop     edi
_F000:FFA4 5B                                pop     bx
_F000:FFA5 C3                                retn                                        ; Return Near from Procedure
_F000:FFA5
_F000:FFA5                   ReadPCI_byte_S  endp
_F000:FFA5
_F000:FFA6
_F000:FFA6                   ; =============== S U B R O U T I N E =======================================
_F000:FFA6
_F000:FFA6                   ; Stack version
_F000:FFA6
_F000:FFA6                   ; __int32 __cdecl WritePCI_byte_S(__int32 address, __int32 value)
_F000:FFA6                   WritePCI_byte_S proc near
_F000:FFA6
_F000:FFA6                   address         = dword ptr  2
_F000:FFA6                   value           = dword ptr  6
_F000:FFA6
_F000:FFA6 53                                push    bx
_F000:FFA7 66 57                             push    edi
_F000:FFA9 56                                push    si
_F000:FFAA BB AF FF                          mov     bx, offset return
_F000:FFAD EB C3                             jmp     short WritePCI_byte_SL              ; Stack Less version, return to the address, written in bx (jmp bx)
_F000:FFAD
_F000:FFAF                   ; ---------------------------------------------------------------------------
_F000:FFAF
_F000:FFAF                   return:                                                     ; DATA XREF: WritePCI_byte_S+4o
_F000:FFAF 5E                                pop     si
_F000:FFB0 66 5F                             pop     edi
_F000:FFB2 5B                                pop     bx
_F000:FFB3 C3                                retn                                        ; Return Near from Procedure
_F000:FFB3
_F000:FFB3                   WritePCI_byte_S endp
