My English is also at the level of
My English is also at the level of translate.google.com:)
Replace the fuse on the incandescent lamp (~ 60W) for the protection of power transistors. Find optocoupler, which controls the main power
If the output is not short circuit, jumper pin 2 coupler to the ground and if the lamp is not lit, measure the output voltage...
