Hello, > Asus P5gc-mx mother board has Winbond 25x04vaiz
and the log is below:
18:01:31.06: UniFlash v2.00.SPI.RC01 started: C:\UF\UNIFLASH.EXE /log 18:01:31.11: Flat Real Mode initialized 18:01:31.83: BIOS CNTL=00000000 18:01:31.83: SpiBar base address=FED1C000 18:01:31.83: BootBIOSDest=04 18:01:31.83: SPIS=0004 18:01:31.83: SPIC=4140 18:01:31.83: SPIA=00000000 18:01:31.83: SPID0=00000000000030EF 18:01:31.83: SPID1=0000000000000000 18:01:31.88: SPID2=0000000000000000 18:01:31.88: SPID3=0000000000000000 18:01:31.88: SPID4=0000000000000000 18:01:31.88: SPID5=0000000000000000 18:01:31.88: SPID6=0000000000000000 18:01:31.88: SPID7=0000000000000000 18:01:31.88: BBAR=00000000 18:01:31.88: PREOP=0004 18:01:31.88: OPTYPE=D43B 18:01:31.88: OPMENU=5006019F05D80302 18:01:31.88: PBR0=00000000 18:01:31.88: PBR1=00000000 18:01:31.88: PBR2=00000000 18:01:31.88: Programming OPCODES... 18:01:31.88: Write PREOP=0006 18:01:31.88: Write OPTYPE=463B 18:01:31.88: Write OPMENU[0]=05D80302 18:01:31.88: Write OPMENU[1]=C79F01AB 18:01:31.88: done 18:01:31.88: SPI Read Conf in 00000001 is: 18:01:31.88: prefetching=00, caching=00 18:01:31.99: Chipset detected: i945G/GZ/P/PL + i82801GB/R ICH7(R) 18:01:31.99: CMOS size detected: 256b 18:01:31.99: Found DMI 2.4 board info: ASUSTeK Computer INC. P5GC-MX Rev x.xx 18:01:31.99: Intel 9xx method: reg $DC = 00000001 18:01:31.99: Intel 9xx method: reg $DC changed to 00000001 18:01:31.99: Intel 9xx method: reg $D8 = 000080C0 18:01:31.99: Intel 9xx method: reg $D8 changed to 0000FFCF 18:01:31.99: System ROM selected 18:01:31.99: run_opcode(read): op=9F addr=00000000 readcnt=03 18:01:31.99: Enter ich7_run_opcode: opcode=9F offset=00000000 count=03 18:01:31.99: Write SPIC=4262 18:01:31.99: Read result SPID=001330EF
>ECS 945GCT-M2/1333 V1.0A has Macronix MX25L4005APC-12G spi flash and its log is Below.
18:11:08.38: UniFlash v2.00_b05 started: C:\UF\UNIF2B05.EXE /log 18:11:08.38: Flat Real Mode initialized 18:11:08.44: BIOS CNTL=00000001 18:11:08.44: SpiBar base address=FED1C000 18:11:08.44: BootBIOSDest=04 18:11:08.44: SPIS=0004 18:11:08.44: SPIC=4040 18:11:08.44: SPIA=00000000 18:11:08.49: SPID0=FFFFFFFFFF13FF12 18:11:08.49: SPID1=FFFFFFFFFFFFFFFF 18:11:08.49: SPID2=0000000000000000 18:11:08.49: SPID3=0000000000000000 18:11:08.49: SPID4=0000000000000000 18:11:08.49: SPID5=0000000000000000 18:11:08.49: SPID6=0000000000000000 18:11:08.55: SPID7=0000000000000000 18:11:08.55: BBAR=00000000 18:11:08.55: PREOP=0006 18:11:08.55: OPTYPE=4638 18:11:08.55: OPMENU=C79F01AB05D80390 18:11:08.55: PBR0=00000000 18:11:08.55: PBR1=00000000 18:11:08.55: PBR2=00000000 18:11:08.55: Programming OPCODES... 18:11:08.55: Write PREOP=0006 18:11:08.55: Write OPTYPE=4638 18:11:08.55: Write OPMENU[0]=05D80390 18:11:08.55: Write OPMENU[1]=C79F01AB 18:11:08.55: done 18:11:08.60: SPI Read Conf in 00000001 is: 18:11:08.66: prefetching=00, caching=00 18:11:08.71: Chipset detected: i945G/GZ/P/PL + i82801GB/R ICH7(R) 18:11:08.71: CMOS size detected: 256b 18:11:08.71: Found DMI board info: ECS 945GCT-M2 ECS 18:11:08.71: Intel 9xx method: reg $DC = 00000001 18:11:08.71: Intel 9xx method: reg $DC changed to 00000001 18:11:08.71: Intel 9xx method: reg $D8 = 000080C0 18:11:08.71: Intel 9xx method: reg $D8 changed to 0000FFCF 18:11:08.71: System ROM selected 18:11:08.71: run_opcode(read): op=9F addr=00000000 readcnt=03 18:11:08.77: Enter ich7_run_opcode: opcode=9F offset=00000000 count=03 18:11:08.77: Write SPIC=4262 18:11:08.88: Read result SPID=FF1320C2 18:11:08.88: RDID(9F) returned:C2 20 13 18:11:08.88: run_opcode(read): op=90 addr=00000000 readcnt=02 18:11:08.88: Enter ich7_run_opcode: opcode=90 offset=00000000 count=02 18:11:08.88: Write SPIC=4102 18:11:08.99: Read result SPID=FF13FFFF 18:11:08.99: REMS(90) returned:FF FF 18:11:08.99: run_opcode(read): op=AB addr=00000000 readcnt=01 18:11:08.99: Enter ich7_run_opcode: opcode=AB offset=00000000 count=01 18:11:08.99: Write SPIC=4042 18:11:09.10: Read result SPID=FF13FF12 18:11:09.10: RES(AB) returned:12 18:11:09.10: Found spi flash chip MX25L4005A 18:11:09.10: Allocating memory block 00400000 18:11:09.10: Allocating memory block 00400000 18:11:09.10: Allocating memory block 00001080 18:11:09.10: Flash ROM chip detected: Macronix MX25L4005A 18:11:09.10: Flash ROM ID: C200,2013 18:11:09.15: UniFlash running in interactive mode 18:11:11.18: BIOS image saved to file backup.bin 18:11:12.45: Exiting UniFlash... 18:11:12.45: Intel 9xx method: restoring reg $DC from 00000001 18:11:12.45: Intel 9xx method: restoring reg $D8 from 0000FFCF 18:11:12.45: Turning off logging, shutting down to real mode ------------------------------------------------------------------------------
in Both motherboards, SPI flash back image file (backup.bin) is of 4 Mbyte instead of 4Mbit (i.e 512Kbyte).
Thanks alot for your reply. Уважаемый raj , не стоит писать свои коментарии по 6-8 раз. Гостевые коментарии публикуются после проверки модераторами.
Hello,
18:01:31.88: done
18:01:31.99: RDID(9F) returned:EF 30 13
18:01:31.99: run_opcode(read): op=AB addr=00301300 readcnt=01
18:01:31.99: Enter ich7_run_opcode: opcode=AB offset=00301300 count=01
18:01:32.05: Write SPIC=4042
18:01:32.05: Read result SPID=00133012
18:01:32.05: RES(AB) returned:12
18:01:32.05: Found spi flash chip W25X40
18:01:32.05: Allocating memory block 00400000
18:01:32.05: Allocating memory block 00001080
18:01:32.05: Flash ROM chip detected: Winbond W25X40
18:01:32.05: Flash ROM ID: EF00,3013
18:01:32.10: UniFlash running in interactive mode
18:01:42.59: BIOS image saved to file backup.bin
18:01:47.59: Exiting UniFlash...
18:01:47.59: Intel 9xx method: restoring reg $DC from 00000001
18:01:47.59: Intel 9xx method: restoring reg $D8 from 0000FFCF
18:01:47.65: Turning off logging, shutting down to real mode
and
18:11:08.55: done
