В модуле Strings есть такие строки:
HDD Master ID: HDD2 Master ID:
This setting enables or disables 32 bit IDE data transfers.
32 Bit I/O:
Cylinders:
Select the method for moving data to/from the drive.
Autotype the drive to select the optimum transfer mode.
Transfer Mode:
Heads: 1 10 11 12 13 14 15 16 2 3 4 5 6 7 8 9
Enable or Disable the IDE Controller.
Total Sectors: 16 Sectors 2 Sectors 4 Sectors 8 Sectors
Specify the number of sectors per block for multiple sector transfers.
'MAX' refers to the size the disk returns when queried.
Multi-Sector Transfers: Fast PIO 1 Fast PIO 2 Fast PIO 3 Fast PIO 4 FPIO 3 / DMA 1 FPIO 4 / DMA 2
Standard Sectors: Maximum Capacity: IDE - Device 31, Function 1:
User = you enter parameters of hard-disk drive installed at this connection.
Auto = autotypes hard-disk drive installed here.
1-39 = you select pre-determined type of hard-disk drive installed here.
CD-ROM = a CD-ROM drive is installed here.
ATAPI Removable = removable disk drive is installed here.
Type: User Mode 0 Mode 1 Mode 2 Mode 3 Mode 4 Mode 5 Mode 6
Selects the Ultra DMA mode used for moving data to/from the drive.
Ultra DMA Mode:
Enabling LBA causes Logical Block Addressing to be used in place of Cylinders, Heads & Sectors.
LBA Mode Control:
Enable Native IDE support for WINXP by setting this item.
The NATA Package will be created if this item is set to Enabled.
Changing this item will have no effect in WIN98, WINME, or WIN2K. Native IDE Support:
Значит мона наверное менять настройки, а раз их не видно при входе в сетап - возможно стоит пароль супервизора, а входите под юзером, поэтому и не видно, нужно мануал от бука читать.
