* user warning: Got error 28 from storage engine query: SELECT t.* FROM term_node r INNER JOIN term_data t ON r.tid = t.tid INNER JOIN vocabulary v ON t.vid = v.vid WHERE r.vid = 19300 ORDER BY v.weight, t.weight, t.name in /home/rombyportal/public_html/modules/taxonomy/taxonomy.module on line 618.
* user warning: Got error 28 from storage engine query: SELECT t.tid, t.* FROM term_data t INNER JOIN term_node r ON r.tid = t.tid WHERE t.vid = 1 AND r.vid = 19300 ORDER BY weight in /home/rombyportal/public_html/modules/taxonomy/taxonomy.module on line 603.
* user warning: Got error 28 from storage engine query: SELECT DISTINCT b.* FROM blocks b LEFT JOIN blocks_roles r ON b.module = r.module AND b.delta = r.delta WHERE b.theme = 'romby6_light' AND b.status = 1 AND (r.rid IN (2) OR r.rid IS NULL) ORDER BY b.region, b.weight, b.module in /home/rombyportal/public_html/modules/block/block.module on line 407. ?????????
..Ну не знаю я HTTP ,PHP и пр. Или это так надо ???
Что за надписи появились :
