Из найденного на просторах инета: Я тоже склоняюсь
System Configuration Data Write Error
This message indicates that the system configuration has changed (such as an expansion card has been added) but the configuration data could not be updated. This is normally caused by the BIOS program enable jumper being in the disable position. For configuration changes to be correctly recorded the jumper must be in the enable position.
Я тоже склоняюсь к варианту замены флешки.
