Category:
-> Power Management
-> Supervisory Circuits
Description:
Synchronous Voltage Mode Controller for Distributed Power Supply Applications
The SC2602 and SC2602A are low-cost, full featured,
synchronous voltage-mode controllers designed for use
in single ended power supply applications where efficiency
is of primary concern. Synchronous operation allows for
the elimination of heat sinks in many applications. The
SC2602s are ideal for implementing DC/DC converters
needed to power advanced microprocessors in low cost
systems, or in distributed power applications where efficiency
is important. Internal level-shift, high-side drive
circuitry, and preset shoot-thru control, allows the use of
inexpensive N-channel power switches.
SC2602s features include temperature compensated
voltage reference, triangle wave oscillator and current
sense comparator circuitry. Power good signaling, shutdown,
and over voltage protection are also provided.
Part number: SC2602STRT
Category:
-> Power Management
Description:
Company: Semtech Corporation semtech.com/
Cross reference search
You query search: SC2602STRT return no results.
You query search: SC2602 return no results.
Пока ничего не выловилось...
Со второй могу только кинуть это:
Possible equivalence(s) found for: sc 1565
SC1565 -> CM3003-15SA
SC1565 -> CM3003-18SA
SC1565 -> CM3003-25SA
SC1565 -> MIC3715
SC1565 -> MIC3910
SC1565 -> MIC3910
SC1565 -> MIC3915
Лезьте на сайт производителя и там уже надо будет разгребаться точнее...
С УВАЖЕНИЕМ, ALEX.
"...Вся наша жизнь - осциллограмма, с её взлётами и падениями..."
"Бен Ла Дента +" сеть стоматологий...
Лом,
