Помогите настроить
У меня есть CISCO 350.
Его не видят в радио. Статус мигает езернет тоже, а радио нет.
Разобрал, там радиомодуль отдельный. на нем статус тоже мигает. а радио мигает только при старте и молчит.
Помогите настроить!
! CONFIGURATION of Cisco WGB350 V8.85 WGB350_4f6b08
configuration radio ssid "tsunami"
configuration radio rates 1_11
configuration radio basic_rates 1
configuration radio world off
configuration radio i80211 rts 2048
configuration radio i80211 Privacy encryption off
configuration radio i80211 Privacy auth open
configuration radio extended parentid any
configuration radio extended parent_timeout off
configuration radio extended count_retry 64
configuration radio extended refresh 100
configuration radio extended diversity on
configuration radio extended power full
configuration radio extended stationary off
configuration radio extended fragment 2048
configuration security mode off
configuration security username ""
configuration ethernet active on
configuration ethernet transparent off
configuration ethernet remove all
configuration ethernet staletime 700
configuration ethernet keep off
configuration identity bootp_DHCP off
configuration identity name "WGB350_4f6b08"
configuration identity class "WGB350"
configuration identity inaddr 192.168.200.001
configuration identity inmask 255.255.255.000
configuration identity routing delete all
configuration identity dns1 000.000.000.000
configuration identity dns2 000.000.000.000
configuration identity domain ""
configuration identity location ""
configuration identity contact ""
configuration console delete all
configuration console communities remote off
configuration console type ansi
configuration console linemode on
configuration time time_server 000.000.000.000
configuration time sntp_server 000.000.000.000
configuration time offset 0
configuration time dst off
configuration pspf off
statistics display_time 10
association niddisp numeric
filter multicast default forward
filter multicast remove all
filter node ethdst forward
filter node remove all
filter protocols default off
filter protocols unicast off
filter protocols remove all
filter direction both
diagnostics load ftp dest 000.000.000.000
diagnostics load ftp username ""
diagnostics load ftp filename ""
diagnostics load distribute type firmware
diagnostics load distribute control newer
diagnostics load distribute remove all
logs printlevel severe
logs loglevel all
logs ledlevel error/severe
logs bnodelog off
logs snmp trapdest none
logs snmp trapcomm "public"
logs snmp loglevel off
logs snmp authtrap off
logs syslog 000.000.000.000
logs syslevel error/severe
logs facility 16
logs rcvsyslog on
Вот лог настроек.
Спасибо заранее
Аватар пользователя blood
Я уже нифига не помню как руляться циски. тем более 350ые:) но меня смутила вот эта строчка :
поробуй её убить.
See you later alligator....
Попробовал перенастроить:
configuration radio world on
configuration radio extended stationary on
configuration console communities remote on
association niddisp name
filter direction to_radio
diagnostics load distribute control any
logs printlevel all
logs loglevel all
logs bnodelog off
logs snmp loglevel all
logs facility 16
logs rcvsyslog off
Его пока не слышно.
сбрось в дефот и настрой по новой:)- рекомендации лучших цисководов.
