Всем, кому интересно, сообщаю, что есть такая версия:
AWDFLASH v8.73 (08/03) (C)Phoenix Technologies Ltd. 2006 All Rights Reserved Usage: AWDFLASH [FileName1] [FileName2] [/[/...]] FileName1 : New BIOS Name For Flash Programming FileName2 : BIOS File For Backing-up the Original BIOS ?: Show Help Messages py: Program Flash Memory pn: No Flash Programming sy: Backup Original BIOS To Disk File sn: No Original BIOS Backup Sb: Skip BootBlock programming Wb: Always Programming BootBlock cd: Clear DMI Data After Programming cc: Clear CMOS Data After Programming cp: Clear PnP(ESCD) Data After Programming LD: Destroy CMOS Checksum And No System Halt For First Reboot After Programming Tiny: Occupy lesser memory QI: Qualify flash part number with source file E: Return to DOS After Programming R: RESET System After Programming F: Use Flash Routines in Original BIOS For Flash Programming cks: Show update Binfile checksum cksXXXX: Compare Binfile CheckSum with XXXX vgaXX: Change to VGA mode XX(Hex value). ch: Update HOLE. Hx: Only update the specified Hole(0~7). NVMAC:XXXXXXXXXXXX NVGUID:XXXXXXXXXXXXXX Support nForce Input MAC,GUID Function,with "/wb" to update MAC and GUID. Example: AWDFLASH 6A69R000.bin /py/sn/nvmac:xxxxxxxxxxxx/wb
Похоже здесь лежит
Jazz, Blues & Rock'n'Roll фарева!
