Новый CBROM 1.15 от Asus (32 Bit Windows)
Появился CBROM 1.15 от Asus (32 Bit Windows). Выковырнут из AsusUpdate V71203 с помощью ResThief.
rapidshare.com/files/65999336/Asus_CBROM32_115.ZIP
ссылка на исходный материал для ковыряния ftp.asus.com.tw/pub/ASUS/misc/utils/AsusUpdt_V71203.zip
CBROM32 V1.15 [Oct  3 2007 Release] (C)ASUSTeK Computer Inc. 2007
cbrom32 InputFile [/other] [8000:0] [RomFile|Release|Extract]
cbrom32 InputFile [/D|logo|vga....] [RomFile|Release|Extract]
          InputFile   : System BIOS to be added with Option ROMs
          /D          : For display all combined ROMs informations in BIOS
          /epa|epa1-7 : Add EPA LOGO BitMap to System BIOS
          /logo|logo1-7: Add OEM LOGO BitMap to System BIOS
          /osb_logo|osb_logo1-7: Add OSB LOGO BitMap to System BIOS
          /osb_bmp|osb_bmp1-7: Add OSB CPU BitMap to System BIOS
          /oem0-7     : Add special OEM ROM to System BIOS
          /err        : Return error code after executed
          /btvga      : Add VGA ROM to Boot Rom Block Area.
          /isa        : Add ISA BIOS ROM to System BIOS.(/isa Filename [xxxx:0])
          /vga, /logo, /pci, /awdflash, /cpucode, /epa, /acpitbl, /vsa, /hpm
          /hpc, /fnt0 - 5, /ros, /nnoprom, /mib, /group0-5, /NoCompress
          /jpeg|jpeg1-3: Add JPEG LOGO to System BIOS
          /rpb        : Add RPB ROM to System BIOS
          /ver        : Add version table of source code to System BIOS
          /jpeg_eng   : Add JPEG engine to System BIOS
          /nc_cpucode : Add non-compress cpu code
          /srom0-4    : Add software ROM
          /setup0-1   : Add setup ROM
          /biosf0-9   : Add BIOS feature ROM
          /GV3        : Add GV3 ROM
          /CALS       : Calculate ROM Compress size but not add ROM in BIN file
          /NVMM       : Add nVIDIA memory module
          /MPDRV      : Add TPM MP driver
          /MADRV      : Add TPM MA driver
          /TCGSMI     : Add TCG 32bit SMI code
          /SLPKey     : Add SLP 2.0 Public key
          /SLPMarker  : Add SLP 2.0 Marker
          RomFile     : File name of option ROM to add-in
          noreserve   : No reserve system color for BMP logo
          keepsize    : Keep orginal BMP size for Logo
          Release     : Release option ROM in current system BIOS
          Extract     : Extract option ROM to File in current system BIOS
                      <<< Examples >>>
            cbrom32 6a69s000.bin /D
            cbrom32 6a69s000.bin /VGA filename
            cbrom32 6a69s000.bin /VGA filename /ERR
Аватар пользователя Compiller
Дрессируем коров :)
Для тех кто будет ковыряться дальше в версии asus update V7.13.01версия cbrom таже  1.15
Подробнее ковыряется фаил winflash.exe ресурс TOOL ---AWDSLP извлекается из файла и удаляется все лишнее до заголовка 4d5a90
Пытаюсь вскрыть BIOS от A7V600 - этот CBROM его не признаёт.
Здесь нашёл - xxsj.net/Mainboard/tools/acbrom.zip
В MyLogo оно явнее видно
оно там тоже в ресурсах в секции TOOL но подписано CBROM.
Дрессируем коров :)
